RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Pull Pull controls?? (https://www.rcuniverse.com/forum/kit-building-121/5177639-pull-pull-controls.html)
BRITTURB 12-29-2006 10:50 AM
I need help as I am going to install my first set of pull/pull controls.
I don't know the first thing about it other than what I can see in pictures.
Any info appreciated.
They are going in the Balsa USA Eindecker 90.
Charlie P. 12-29-2006 11:06 AM
RE: Pull Pull controls??
Here's a start on the geometry.
http://www.swbmfg.com/rudex.html
Sullivan, DuBro and Great Planes all market a 4-40 size pull-pull rigs that would work well in the Eindecker. I have been gearing up for one on another model and decided to fashion a central bell-crank at the rear of the servo tray and move the bellcrank with the servo. That way I can make servo adjustments while leaving the pull-pull connections tensioned. Ball bearing rod ends eliminate as much of the slop as possible, but the following cable can be relatively loose; as the pulling cable is the only tensioned one. Ideally, the opposite cable should be snug but not tight.
GarySS 12-29-2006 11:30 AM
The first thing with Pull-Pull geometry is to make sure you have as close to a perfect rectangle arrangement with the servo end being one end of the rectangle and the control horn end as the other. Space the end of the lines equal distant out from the pivot point at each end. If you want to cross the lines that's OK.
Campy 12-29-2006 03:05 PM
Here are several links for pull-pull. They will tell you what you need to know.
http://members.cox.net/bdfelice/Pull-pull/pull-pull.htm
http://webpages.charter.net/bobad/pullpull.htm
http://www.geocities.com/roger_forgues/PullPull.html
http://www.mindspring.com/~rellis2/rcpattrn/ppull.htm
http://www.modelairplanenews.com/cli..._pullpull1.asp
Here is the URL to Alan's RC page.
http://homepages.ihug.co.nz/~atong/ This site is LOADED with RC information. Basically, ANYTHING you want to know RC you will find here.
