1/4 Scale SIG Spacewalker
On p24 of the booklet: "Do not try to cover the ABS plastic parts......". On p23: "The covering on the wing can be extended to cover the entire ABS wingtip."
I wish to cover the total airframe with Solartex. The question is: do I cover the wingtips ot not? |
RE: 1/4 Scale SIG Spacewalker
Check a piece of scrap ABS to see how much heat it can stand. If it melts easily, then a sealing iron may melt it when you cover.
solartex is pretty low temp....you should be fine. try a piece like said, but i think u'll be ok. ive covered foam and plastic with solartex before, it didnt melt that. works good. probly my fav covering for big stuff. i dont know what the wing tips look like on your spacewalker, but if they are small enough, heat the covering with a gun and pull it over. that way the heat isnt concentrated like the irom would be.
solartex will work just be darn careful with the heat gun or iron.trust me too much heat and the abs meltsdown.lol.just take time and go slow!
| All times are GMT -8. The time now is 04:06 PM. |
