RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   brittle ca hinges (https://www.rcuniverse.com/forum/kit-building-121/548251-brittle-ca-hinges.html)
specialk566 02-11-2003 01:38 AM
brittle ca hinges
I'm about to acquire an older ultimate biplane that is structurally sound, but in bad need of recovering. All the ca hinges are intact, but I'm not sure I trust them due to the age and background of the kit. (It was acquired by a friend in a trade from a guy who just let it sit around) The plane doesn't appear to be crashed or repaired in any way, but I am wondering if it is safe to leave the hinges intact and just recover it, or if I should rehinge it too. Could someone please enlighten me on ca hinge durability and longevity?
Sense963 02-11-2003 04:02 AM
brittle ca hinges
They should last, but if you're in any doubt, unhook the radio and wear 'em out with manual flexing. I would do that then inspect it very closely. Any questionable appearance and I would probably re-hinge. Your call...
p39 02-11-2003 04:47 AM
brittle ca hinges
It may be easier to recover if you removed the control surfaces anyway. CA hinges are easy to just cut apart... and rehinge next to the old ones.
Rick
FlyingPilgrim 02-11-2003 05:29 AM
brittle ca hinges
Ditto on what p39 said. How can you hope to re-cover a plane without removing the control surfaces??
MinnFlyer 02-11-2003 05:25 PM
brittle ca hinges
I would say that if your going to re-cover, you might as wekk cut them off. But I wouldn't use CA hinges again because you can't reinstall them where the old ones were, and placing them next to the old ones won't put them where you need them. I would go with Robart Hinge Points.
p39 02-11-2003 10:04 PM
brittle ca hinges
I haven't had any problem rehinging ca hinges. And I figure 1/2" one way or another won't make all that much difference. If you've got access to GP hinge tool- it makes the whole process a whole lot easier.
