Saito 150 inverted on CG Ultimate?
Hi All,
Has anyone tried mounting a Saito 150 inverted on the CG Ultimate. I see alot of folks mount sideways but have a good chunk of the head and valve covers out the right side (lateral balnce issue?). I was wondering if there is a problem inverting a Saito 150 on this plane. I'm building the kit now and don't know which direction to go... Any help appreciated. Best, Harold |
Hi Punkey , I have been putting 4/s inverted in scale models for years , last one was a Saito 180 . I usually put it at 7 oclock position looking from front of plane , a big benefit is to use an "on board " battery to glow plug . need a limit switch to throttle servo , so that as you go to 1/4 or so throttle on cut back the batt; kicks in to glow the plug . Then you won't have any problems , honest!
Thanks!
Thanks for the reply.
Best, Harold |
The cowling is definitely wider than it is tall toward the front. You will have a lot of cylinder sticking out (down). I'm not sure, but it may make installation and removal of the cowling difficult. I would take a good look at the plans before you do it. My Saito 120 is mounted 20 degrees down from horizontal. I think it looks fine.
Hi guys, It was a while back that I had the C.G, Ultimate , I had a
120 Enya "R" in it . I thought really that Harolds query was if a 150 Saito would run ok without quitting if he put it in inverted, so I said "yes" . Not familar with how much space in the cowl , but probably [without looking at it] more room at bottom than on side ? Any way for that part of question I will leave it to you guys . regards AL |
