TF P-40
Started my Top Flite P-40 today and this being my second kit I'm sure there will be screw up's.For some reason I'm starting to like kits better than arf's.I will post pics later.Built the hor. stab. tonite,went together good.Once I figured out how to find the parts and pieces I had to cut it went fine.
RE: TF P-40
You may want to check out the warbird and scale forum as there are a couple of build threads going on the P-40, which may include some ideas that can make your build easier. Good Luck, Dave
| All times are GMT -8. The time now is 09:32 AM. |
