RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Large format copier accuracy? (https://www.rcuniverse.com/forum/kit-building-121/5794709-large-format-copier-accuracy.html)
jacobezzell 04-30-2007 10:12 PM
I just picked up a Hog Bipe kit and I want to make a "backup" of my plans to do the building off of. I did this w/ my LT-40 kit, but discovered halfway through that the copier at Kinkos didn't do a perfect 1:1 duplication. No big issues, but it was frustrating that my wing wasn't lined up right on the plans. I went to a different place today, an Officemax, and had the same issue with the Hog Bipe plans.
Any suggestions? Anyone have better luck than me? I guess I should try looking for a place that does blueprint duplication.
RCKen 04-30-2007 10:19 PM
RE: Large format copier accuracy?
jacobezzell,
I do the same thing with all of my plans for any kit that I'm building. What you need to do is check the accuracy of the plan right there on the spot. The people in the copy center are normally happy to work with you to get the copy right (make sure you tell them that it's got to be accurate). They can make adjustments to the machine to get the output to match the original. Also, they shouldn't charge you for copies that aren't right. It might take a little bit of time to get them done, but it's easy enough to get the machines adjusted properly.
Ken
jacobezzell 04-30-2007 10:27 PM
Thanks Ken, maybe I'll try going back to kinkos and see if they can do the adjustment you are talking about. The doofus at Officemax wasn't any help at all.
huck1199 04-30-2007 10:30 PM
I beleive it is illeagle for a copier to have 100% fidelity. Most copiers are 99 or 101 %.
Gray Beard 04-30-2007 10:35 PM
I used Kinkos in two different citys and both of them were dead on. Like Ken said, check the copy with the originals and make sure they are right. That way the folks there can dial in there machines correctly.
blueline 04-30-2007 10:39 PM
I service office equipment everyday and it is not illegal. I don't know where huck got his info but he is not correct, all copiers default to 1:1 or 100%. When you go back to make copies just ask for assistance and they'll be more than helpful.
huck1199 05-01-2007 02:37 AM
BlueLine
Seveal years ago I was asked by some users (i was a system programmer in a tech dept responsible for hardware as well as software) why our copiers did not give the option for 100% copy repoduction. The options skipped from 99 to 101 percentage. I was curiuos and contacted the vendor (Konica, if I remember correctly). I was told that the Bureau of Engraving (Treasury Dept) had enacted a commercial restriction on copier manufacturers to limit the copy sizes outside of the 100% size. They said they complied to the standard in thier software as well as the hardware; e.g. the options the user had to choose from. They also said many manufacturers complied on the hardware side but not on the sofware side; e.g. hey offered 100% but really gave you 99 or 101. Along with other variables such as ambient temp. and humidity as well as paper moisture content (the machine heats the plastic ink to bond it to the paper) pretty much assured that the copy would not be 100%. This whole effort was to thwart couterfeiting money and stock certificates.
Jacque 05-01-2007 07:03 AM
I don,t know about the copying laws ,but I use a blue print co. and they are right on
ag4ever 05-01-2007 10:02 AM
I work for a commercial construction company and we have our own Xerox full sized copier just like what Kinkos uses (actually is was a refirbused unit that was more than likely used at a Kinkos). We use this copier all the time to reproduce plans for construction where the accuracy is very important. Ours will do a 100% copy and if it did not, we would have it serviced until it did do an accurate 100% reproduction. (The sad fact is the thing does require service about once to twice a week, but we do run like 2,000 feet per week on a normal week and on busy weeks it would not be uncommon to run 10,000 feet through the machine.)
I don't know if there is a law prohibiting 100% accurate reproduction on color copiers, but even that would be doubtful since you can alway use a scanner and a printer for the same result.
I now scan all my plans to a digital jpg file that is a 1:1 ratio so it can be printed at any time. I also archive the original plans so if I need them, I will have an original set undisturbed.
For my TF GS Corsair build, I have used the JPG as a background image in AutoCAD and I am redrafting some of the parts to be more scale accurate and I will reprint the plans once I am done.
jquid 05-01-2007 11:30 AM
I beleive the law only says that you cannot make 100% copies of currency. You can blow up a dollar and use it for an ad, or poster for carwash etc. or shrink it. But it is illegal to make 1:1 copies. Copiers that can duplicate some of the finer lines of currency I also believe have to be registerd with the Feds.
Most likely Kinkos put that in their softwre so they did not have to worry about it, or worry about emp's making "OT" pay.
WacoNut 05-01-2007 01:09 PM
I scan my plans into our system at work and print them on a laser plotter, pefect 1:1 copies every time. I have around 50 giant scale plans on file;)
Always check the scaling to make sure you are getting a 1:1 copy before cutting the 1st piece of wood.
Anthony
Whistling Death 05-01-2007 03:31 PM
I use the scanner we have at work. It reproduces copies 100% accurate. I make 3 copyies then put the orginals in a tube and store them away. I make 3 so I can cut use 2 of them to cut into smaller pieces so I can use a smaller work area.
jacobezzell 05-01-2007 04:11 PM
Thanks for the replies. I tried kinkos again, no good. Then I went to a place that does nothing but blueprint duplication. Holey Bejeebers! Perfect copy, and it cost 1/4 of what Kinkos wanted. If you don't have access to a large format copier at work, do yourself a favor and look up blueprint duplication in the yellow pages. Support your small businesses! They know what they are doing! :)
ag4ever 05-01-2007 05:02 PM
For large jobs, we still send them out to be scanned and reproduced, it is much cheaper than paying one of our workers to stand in front of the scanner and feed one sheet at a time.
blueline 05-01-2007 05:21 PM
Afternoon Huck, I spoke with the engineers this afternoon and was laughed at for asking such a fundamental question, its is a true 1:1 copy. Wether you purchase a .5copy or 85 copy a minute machine, well, for that matter my multifunction fax/scanner/printer at home defaults to 1:1 or 100%. I don't know what else to tell you.
Ag4ever, I can't empathize with your situation, I'm always going to construction sites (which by there very nature is a dirty environment) to clean machines. It sounds like your in need of a higher volume machine, say a 20k-40k copy a month type of machine, ha, ha!
BentMetal 05-01-2007 08:28 PM
My personal experience with the many copies I’ve made over the years is that scanners tend to stretch the drawings a bit. The top starts out pretty close and by the end it can be off quite a bit depending on how big the plan is. You then have it printed on paper that is less than optimum for plans and so you will have a lot of shrinkage and expansion depending on the environment. It can very quite a bit with the various printers, but that is probably what happened. Printing directly from a CAD drawing is obviously considerably more accurate, the problem comes from the scanning and the various scanners in my opinion.
Luke
Kelsey_B 05-02-2007 03:12 PM
I just had a set of plans copied at a local place. I told the lady I needed an accurate copy. I explained that I build on them and the copies couldn't be bigger or smaller than the originals. She said no problem. I got back to work, unrolled them, and they are off. It's just "STIK" plan, but I'm just aggravated that I did not get what I asked for. I could probably make due with them, but I'm tempted to go back tomorrow and see if they can do a better job. They charged me 35.00 for two 36" x 58" sheets.
blueline 05-02-2007 03:52 PM
HOLY S*#T, how much? Kelsy, if it were me i'd be returning them and getting what you paid for! Here's what I do when I'm in the field and ensuring I'm getting a 1:1. Hold your copy on top or bottom of your original then hold it up to a bright light, you will then be able to tell with 100% certainty if its a full size copy. I hope this is of some help, if you have any questions shoot me a PM or email. Good luck and be well.
Kelsey_B 05-02-2007 04:03 PM
The price was 35.00 total. She said its based on $1.25 per Sq. ft. I didn't think that was too much, I'm just a little mad right now. I'll take them back tomorrow and see what they can do.
jacobezzell 05-02-2007 05:50 PM
$35?? [:-] See thats why I'm saying to shop around. the place I got it done charged $0.20 per square foot.
alfredbmor 05-02-2007 08:35 PM
What the law prohibits is to sale those copies and have a profit, the material has a copyright so you should be very careful with those copies and prove at all times that you own the original material and that the copies are only for personal back up purposes.
bigtim 05-02-2007 10:18 PM
I must be lucky went to kinkos for a copy of my Royal FW A8 plans and there right on the $ and they cost 9$ for both sheets I did ask that I get a accurate copy because I would be using them for const. porposes no problem was the answer if they were off then she would have run me another set no charge.
woolfster2 05-02-2007 10:42 PM
Being in the copier repair business for a long long time here is a real easy way to make sure you have a 100% copy. take a fine graded scale/ruler, the longer the better; and lay it on the copier glass lengthwise make a copy and then move it to front to back setting it to far left, compare it to your scale. most copiers are not set to perfect 100%. make changes to the increase and decrease buttons on the machine and see what happens. I have set up many machines to make perfect 100% size copies so it can be done. Most places can't do this right away because it will take a tech to do this.
blueline 05-02-2007 11:22 PM
Wolf, it sounds like he doesn't own or lease a copier, he has take it elsewhere to have copies made for him. He's not going to be able to go through the process you described. Its up to the key-op to take care of the customer (ag4ever).
woolfster2 05-03-2007 01:40 AM
YES I THINK YOU ARE CORRECT.
Stripes 05-03-2007 06:49 AM
I take a ruler and mark off an accurate ruler line on the original. Then when the copy comes out it is easy to tell right there if it is correct.
Kelsey_B 05-03-2007 09:31 AM
I just called Kinko's, and the guy said he would charge $0.75 per sq. ft. He also assured me he would get a 1:1 copy to the original.
Since I agreed to the $1.25 at the local place, I feel obligated to give them the opportunity to supply correct copies. If they can't, I'll ask for a refund since I told them up front what I wanted.
saramos 05-03-2007 10:54 AM
When you mark out a rule, I suggest that you mark out both vertical and horizontal rules to insure both scale and proportionality.
Scott
Kelsey_B 05-03-2007 01:20 PM
Just got back from the reproduction place. I took my original drawing and showed her how the notched TE lined up with all of the ribs. Then I showed her how her copy did not do the same thing. She was shocked. We went to the back and she showed me where her Zerox machine was set to 100%. Since the copy was a little short, so she tried 102%, and it came just a tad big. Next, she tried 101.5, and the copy came out very close. I wouldn't say its perfect, but its close enough. She told me to remember the setting for next time. I was pleasantly surprised that she ran several copies until I was satisfied.
blueline 05-03-2007 04:04 PM
Kelsey, nice to hear you finally got what you paid for! It appears as though a technician needs to pay a visit to hear place of business, hummm? Take care and be well.
Kelsey_B 05-03-2007 04:32 PM
Thanks Blueline,
I'm definitely in a better mood. My daughter is ready to build her first plane, and I wanted to get started this weekend.
My guess is that the great majority of copies don't have to be a 100% duplicate of the original. Most people just want a copy, and don't need a scaled version. This lady was surprised. She thought being Zerox, 100% meant a full scale copy.
I feeling much better now.
tucker1865 05-05-2007 04:24 PM
My Kinkos copies are about 1% to 2% large. I complained and we ran the copy, not the original, at 98% and it was dead on. They used to be .50 per sq. foot, but have recently gone to .65. Try that approach and see if they will give. If they do, and it it not critical, you have two plans.
Tkeith9512 05-09-2007 06:34 PM
WOW, guess I've been getting lucky with Kinkos. I have used their machines to scan TIFF files (for which they're kind enough not to charge me) and I convert them into PDF as well at home (Kinkos around here WILL NOT print anything large scale unless it's a PDF, and they'll charge $2.50 to convert it). The files, incidently, print the same from PDF or TIFF.
Everything that I've scanned on their large format printer/scanner (36 inch roller) has printed off to within 1/64 or perfect, depending on the original Seems to be highly dependent on the quality of the original and the light permeability of the original paper. The thicker the paper, seems like more light reflects off of it and gives a trued copy. 1/64 is well within the tolerance of most people's cutting, so it's a matter of knowing when to cut the line, and when to leave it and sand to it before removing the pattern.
I recently also discovered the blueprint services of a local architect. Less than 1/2 of the cost of Kinkos, much more knowledgeable, and a heck of a lot nicer folks, what a bonus. They'll get getting all of my business from now on.
Tom
woolfster2 05-10-2007 04:15 AM
SUPER. THE BIGGER THE BETTER
