TCraft engine size help
Hello everyone I just ordered a TCraft kit and it suggests a .32 or larger 2 cycle I realy like the sound of the 4 cycle(stroke) engines and was thinking of putting a 4 c engine on the plane but not sure what size or if this was even a good Idea just thought maybe you guys could steer me in the right direction any help would be appriciated
RE: TCraft engine size help
something in the .50 range I would say
Who manufactures the kit? What is the wing span and the projected weight?
I have built and flown the "Live wire T-Craft" by Hal DeBolt. It flies great with a .45 engine. I have another one in the box waiting to be built. |
thanks for the help guys
4-stroke .26-.30 cu in (4-5 cc)
sounds to small but Ive never owned a 4 stroke so I need some help with what would work SPECIFICATIONS Stock Number: GPMA0155 Wingspan: 56 in (1420 mm) Wing Area: 497 sq in (32 dm2) Weight: 3.75-4.5 lb (1.7-2.0 kg) Wing Loading: 17.5-21 oz/sq ft (53-64 g/dm2) Fuselage Length: 40.75 in (1035 mm) Engine Required: 2-stroke .20-.32 cu in (3-5 cc) or 4-stroke .26-.30 cu in (4-5 cc) Radio Required: 4-5 channel with 5 servos (3 standard: 2 mini) |
superflea says a .50 so maybe thats what Ill try
If this is the Great planes Tcraft, mine flys well on a Saito .30. I have put it on floats though so I am considering a Saito .40. I don't think you need any more than that, and the weight of a larger engine is not going to help.
Regards, Dave |
Any of the four strokes in the 50 range, depends on how you like to fly. The TC is A nice little stunt plane so I like A bit more power. Smaller engines will fly it OK.
Mine was powered with the OS 26 FS (4 stroke) and it was under powered and flew marginally. I think the OS 30 would be about right.
I wouldn't go much more than that however, it is a small airframe. DaveB |
| All times are GMT -8. The time now is 06:46 AM. |
