RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Sullivan tail gear spring (https://www.rcuniverse.com/forum/kit-building-121/632034-sullivan-tail-gear-spring.html)
rajul 03-18-2003 09:45 AM
I have a Sullivan tail wheel gear and I would like to find out what is the best way to fix the spring to the rudder. Could someone kindly give me an idea how to do it, with a pic if possible ? Thanks !
MinnFlyer 03-18-2003 03:56 PM
1 Attachment(s)
Like this:
rajul 03-19-2003 01:18 AM
Minnflyer, thank you very much ! A good picture says a thousand words................
edberry22 03-30-2003 04:58 PM
What if the hole provided is glogged with solder and not aligned with the wheel assy?
can that be corrected without messing up the plastic mount?
MinnFlyer 03-30-2003 05:45 PM
You could try wrapping the plastic and the wire with a wet rag while heating it, so that the heat can't travel down the wire to the plastic.
edberry22 03-30-2003 09:18 PM
I will give that a try tonight after work.....
I also have a dubro assy to use if I mess it up, but I try not to throw 7 bucks away here and there.
William Robison 03-30-2003 10:55 PM
ecajberry:
You also could merely drill it out.
Bill.
edberry22 03-30-2003 11:18 PM
If it was aligned right thats what I would do, but its not.
Or are you suggesting to drill a new hole in the right spot?
William Robison 03-30-2003 11:44 PM
Ed:
Much easier to drill through the solder and bend the end of the spring to adjust the wheel tracking.
And since you bend the spring to adjust wheel centering anyway, I think that would be much better than drilling a complete new hole.
Bill.
jcflysrc 03-31-2003 06:14 AM
Exactly.
edberry22 04-01-2003 12:39 PM
Well after looking over Minn's graphic cloeser (thanks Minn) I realized that my eyes really do suck in my old age. Everything is good with my assy, and I got it installed last night. Have the fuse covered minus some form of trim, but coming along great.
Thanks for all the input guys.
A picture really is worth a thousand words.
