RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Help with wing hight (https://www.rcuniverse.com/forum/kit-building-121/640908-help-wing-hight.html)
azenigma 03-22-2003 01:32 AM
I am about to glue the wings of my stealth sport kit on to the fuse. but am a bit confused. The instructions say to measure the wing tip height at the center of the L. E. This should be 2-1/4". I do not understand where this is. the center of the L.E. seems like it would be in the middle of the front part of the wing but the wing tip is at the end!
FLYBOY 03-22-2003 02:59 AM
What are you trying to do? I assume join the wing half to the other with the center on the table? The place they would be talking about then would be the center of the Leading edge of the wing at the tip. Right where the top rolls around and becomes the bottom on the front of the wing at the tip. I am not at a system I can draw it. Sorry.
Other words, on the tip, draw a line from the center of the leading edge to the center of the trailing edge. That is where they want you to measure the dihedral.
azenigma 03-22-2003 04:26 AM
pict
1 Attachment(s)
okay, I think I understand I marked the picture red were I think I should measure. Is this correct?
Duane
MinnFlyer 03-24-2003 02:55 PM
Correct.
