RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Somethin Extra Horizontal Stab ?????? (https://www.rcuniverse.com/forum/kit-building-121/6410965-somethin-extra-horizontal-stab.html)
Krener 09-25-2007 04:16 AM
1 Attachment(s)
Hey all.
I have attached the horizontal stabiliser onto my SSE, and somehow it shifted while curing[:o]
It's not much, maybe 1mm or so, 2 at the outside (see the pic).
My question is, how bad will this effect the flight characteristics?
(The stab also has a slight kink in it, pretty much every bit of this kit wasn't 'straight')
I would assume that 1mm here or there wouldn't pose a problem much, but than again, I aint no aerodynamics freak either.
Any thoughts???
P.S The vertical stab is crooked, cause I haven't attached that yet :D
bps 09-25-2007 06:02 AM
RE: Somethin Extra Horizontal Stab ??????
1 Attachment(s)
I do not think you will notice any effect from what I see. Put it together and fly, you will love this plane/
JEB:D
yel914 09-25-2007 06:13 AM
You can probably tweak the rudder into position when you install the tail group wire supports. Nothing to worry about.
Krener 09-25-2007 07:24 AM
Thanks guys.
I kinda figured I could correct most of it when I install the wire supports, but thought I'd check anyways.
Cheers
Sean
