Help - Jemco AT-6
1 Attachment(s)
I sold a "good" Jemco kit on Ebay two years ago. Changed my mind and picked up this. [:'(] Wing partially done, parts punched out from the die cut stock. Most of the parts are still in plastic bags. Plans are there and instructions. All injection molded parts are there too.
But wasn't there a guide for the jem-loc assembly? Some additional sheet. Need some help here. I built a Messerschmitt years ago, got it to the finishing stands but than sold it. Young, just married, go figure. :eek:Sold the Sig Kougar and Bridi Big Birdy too, engines ..... [&o]. I hope she doesn't read this. Jim |
RE: Help - Jemco AT-6
Jim: It is not a jig, it is a crutch that all the parts/formers are attached/glued to. I'm not sure about the T-6 but the others that I have seen have this crutch. It should look like the fuse from the top but is cutout in the middle. If you look at the formers, the middle/horizontal slots are for the crutch. I have a partial kit, I will check it later and let you know what you need. I will send it to you. Dave
| All times are GMT -8. The time now is 09:40 PM. |
