RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Sr Telemaster Thrust Lines? (https://www.rcuniverse.com/forum/kit-building-121/6439757-sr-telemaster-thrust-lines.html)
pjwright 10-02-2007 09:35 AM
I'm converting a Sr Telemaster electric ARF to glow, and wonder if anyone with plans for the original kit can provide the correct right- and down-thrust angles?
I've cut out the maple beams which the previous owner had cut for his electric motor (and therefore were now useless to me), and will install an FS-80 on Dubro vibration-reducing motor mounts attached to a beefed-up firewall.
Thanks!
:D
vmsguy 10-02-2007 10:32 AM
RE: Sr Telemaster Thrust Lines?
I was looking at this as well.
I don't have the plans in front of me.
But if memory serves, it's 3 degrees down thrust, which should be built into the firewall installation, and 2 degrees right thrust. I'll double check tonight when I get home.
