Identify this plane
1 Attachment(s)
Can anyone identify this unfinished plane . It probably dates to the 70-80s as that was when the builder was active. It has a 62" wing span and is 48" without the rudder.Trycycle gear with the nose wheel located behind the firewall. motor mount appears to be for a 60-61 engine. It has no formers or mounts for servos or tank. I would like to finish the plane. but would like to know a little more about past perfomance and build tips if available. THANKS
RE: Identify this plane
Jim,
I believe the plane is a fiberglass version of Tony Bonetti's Troublemaker pattern ship. The fuselage shape and wing areas look right. This airplane is being kitted by Eureka models in an all balsa version.. I'm certain that getting a set of plans from them would help you out in build/finishing this plane. More on this plane plus a build thread on the kit can be found in the vintage pattern forum. Good luck with your project. Dan Carolina Custom Aircraft Vintage Pattern Kits |
THANKS I will get right on those sites. Jim
how do you put pictures on posts?
i have an unidentifyable plane in my gallery do you know what the name of it is? |
Jim, that's the F-16 Fighting Falcon, complete with gatling gun and sidewinders missles. Good luck and keep 'em above ground.
That's definately a pattern ship. Did you try posting this on the "Vintage Pattern" forum? I'm sure someone there will recognize it
Looks like a Phoenix 5 to me...
| All times are GMT -8. The time now is 07:55 AM. |
