Rubberized CA???
Anybody use rubberized ca? I have some of that black stuff that I was thinking about replacing epoxy with on a Lazy bee firewall and gear box.
TIA, BC |
Rubberized CA???
Not familiar with it. Do you have a link or website to what it is?
Rubberized CA???
Good stuff
There were several planes at the TOC that were built using this stuff exclusively.If the pro builders don't have a problem with it neither do I.I built a 31% Suhkoi using Cyberbond Flexible CA.Works great.
BTW,Cyberbond has it in clear & black. |
Rubberized CA???
Guess I would have to try it. The only other glue like this I have ever used was good for some things, but with the rubber in it, seemed to have a "give" or movement too it. Over time it let go. Didn't like that. It lasted a long time before it slipped though. Can't say that this will do the same. It isn't the same product so it may not have the same properties. Test it out good and let us know how it works.
Rubberized CA???
we use it at work to assemble speakers, it is very good stuff, pots of it sometimes go missing from the stores!!
it would work well on a firewall |
| All times are GMT -8. The time now is 05:48 AM. |
