source of information
I am a new kid on the block. Where can I access literature to learn the technique of using heat iron/and or/gun to shrink mono-cote type material. Or is the only way of learning to lean over someones shoulder?
The video has helped me. The trick about peeling the backing by using a hobby knife is worth the cost alone. The secret seems to be stretch it as tight as possible while you are applying it.
Here's a couple more sites: http://www.monokote.com/monoinst2.html http://www.info-central.org/finishing_monokote.shtml http://www.coloradohobbies.com/tips.htm http://www.geodesicairoliteboats.com.../monokote.html |
heat shrinking
Thanks fellows. I never even thought there might be a video.
| All times are GMT -8. The time now is 11:37 PM. |
