plastic pinned hinges how do I do this??
I am about to put those plastic 2 piece hinges on my 1/4 scale cub and have NEVER done this. I have always used the CA type. I know that you epoxy them but anyone out there that could give me some start to end step by step help it would be very appreciated. Thanks in advance.
RE: plastic pinned hinges how do I do this??
Cut a slot on the centerline of the stab and elevator where the hinge will be. I start with a razor knife, then open the slot up with a broken off piece of a coping saw blade. Put vaseline on the barrel part of the hinge. Mix epoxy and poke down into the slot to the best of your ability. Smear some more epoxy on the hinge so that it flows through the holes. Put it all together and wipe off the excess epoxy. The hinge pin should be centered on the trailing edge of the stab and the apex of the vee on the elevator.
"The hinge pin should be centered on the trailing edge of the stab and the apex of the vee on the elevator. "
Fill me in on this if you would. I am drawing a blank. My pins are what appears to be straight pins, what do I do with them once I am done? How do I keep them from coming out? They come out real easy. |
Are you trying to install the "robart" style of hinge or the flat plastic hinges? The process is similar but there are some differences in installing either type
I guess I should have put that on here, my bad. I am trying to put the flat ones in. One has a cotter pin, of which I guess you would spread them just a bit, then the others have a straight pin and I guess you clip them and install them and then somehow flatten the end. But I dont know how to do that. This is all new to me. I am getting the slots open like they need to and I am going to use a toothpick to pin them for safety.
I do the hinges a bit different that most people. I wax the hinge line. I use a jewelers' Spure wax because it is red and I can easly see where I've put it and also I've got a ton of it from when I had my store. I like it better that the vassolie as once it hardens back up, it won't smear around. I use an xacto knife and an acohol burner to melt the wax. I scrape a bit of the wax on the blade then heat it until it goes liquid then touch the blade to the hinge line and some will weep off the blade into the hinge line. I do both sides. Use just enough to seal the hinge line, but not get on the blades of the hinges. I've also use the wax used on dental braces and it works well also.
I use 5 minute epoxy and I can set six hinge sides before it starts to kick. I use a small 1oz plastic cup and mix the epoxy in it. As stateded before, use a tooth pick, I shave one side to a flat blade, and work a bit of epoxy into the hinge slot, dip the tip of one blade in the epoxy and smear it on both sides of that blade, the push it in place. Make sure the hinge line is tight to the wing or surface you are hinging. Clean each hinge with acohol and make sure it is straight before moving to the second one. My 4*60 wings have five or six hinges per side, so one half is the maximum you can do at a time before the epoxy kicks. I would really use the 30 minute stuff for you first ones. Once the hinges are set in one surface, the epoxy the slots in the moveable surface, IE elevator or aileron, and smear a bit of epoxy on the exposed blades. Push the moveable surface onto the hinges and make sure they are fully seated with a minimum gap. Again clean up and pushed out epoxy with acohol before it starts to kick off. There will be a bit of epoxy and wax at the hinge line and I clean this off with an xacto knife after it has dried. Keeping the hinges straight is important or you will get a very stiff, if not imovable surface. With th 1/4 scale hinges with the cotter key, I've used a piece of panio wire the size of the cotter key to go through all of the hinges while the epoxy is setting. Be careful not to get any epoxy on the wire or in the hinges and glue the wire in place. That is a mess to resolve. The smaller hinges with the Straight pin usually have the pin mashed on the end opsite the head and are permanatly assembled. If yours are removable, you could put just a slight bend on the end of the wire to keep it from falling out. On and old trainer that I aqured, the hinges had a wire with an L end and the short leg was about 1/8" long. The pins were pushed into the hinges then a spot of epoxy was put o the tip of the L, glueing it to one surface. It seems to work well. I had to do some repairs on it and recover the elevator and rudder. I just popped the epoxy to covering off and then when I was through with the recovering, put the pins back in and spotted them again. On the cotter keys, don't spread them very far. Just open them up with a pocket knife blade by pushing the blade into the slot The brass cotter keys bend just enough to take a slight set and they will no fall out, but can easilly be removed if needed and the re-inserted. If you open them to far, they are dificult to pull out of the hinge. Don |
1 Attachment(s)
Wax?? What A great idea. After sitting in class for A couple of years to become A Dental Lab Tec and working with wax I never gave it A second thought for my hinges, shame on me.
I figured A photo was worth the trouble so I went out and tossed A hinge together so you could see it, something about A 1000 words. I cut the slots and trial fit the controls surface so it is all lined up. Install the hinges and controls, ailerons or stabs then drill the hole for the tooth picks. I cut the picks taper off. I will be using wax from now on but have been using oil on the brass pin for years. I drop about two or three drops of medium CA in the pick hole and it flows along the hinge all by itself so I don't put any glue on the hinge itself. Insert the pick and move on to the rest of the hinges. I try to only drill the pick hole through the hinge about half way through the wood on the other side to keep the CA from flowing out the other side. I do everything from the bottom so you can't ever see the pick bump, even after sanding they tend to show A little after covering. Cutting the slots takes more time then installing the hinges. Also showing you two types of hinge slot guides, on the left is for hinge pins and on the right is for flat type. These are used so you have your hinges centered perfect. Good luck, it's easy!!:D |
| All times are GMT -8. The time now is 09:16 PM. |
