RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   fueling ? (https://www.rcuniverse.com/forum/kit-building-121/706482-fueling.html)
Devo 05-09-2004 01:40 PM
RE: fueling ?
ORIGINAL: hifli
OK, on a two line system -
One line runs from the clunk to the valve, one line runs from the vent to the valve...
Where does the pressure line from the muffler go?
On a two line system, one line runs from the clunk to the fueling valve, then runs from the fueling valve to the needle valve on the engine. The other line from the tank connects to the pressure fitting on the muffler.
hifli 05-09-2004 06:23 PM
RE: fueling ?
Now I got it! I suppose I will have to disconnect the pressure line at the muffler each time I fuel to know when the tank is full and to avoid flooding the muffler with fuel.
