SUPER COVERITE COVERING OR EQUIVALENT
I am looking for Super Coverite covering but it is very hard to find online.
PREFERRABLY: Does anyone know where I can purchase this covering, or an equivalent unfinished pre-adhesived covering? LAST RESORT: If not, although I really want the iron-on, I will use a doped-on variety but do not want to use silkspan or silk. Silkspan is too weak and looks dull and silk is too hard to get tight. Any help is appreciated. |
RE: SUPER COVERITE COVERING OR EQUIVALENT
tower hobby did sell it. I believe it came in the 15' roll. I have purchased some from them earlier.
ORIGINAL: goirish tower hobby did sell it. I believe it came in the 15' roll. I have purchased some from them earlier. |
Have you ever tried Solartex. It is a fabric iron on covering. I just got done covering wings for a Norseman I am working on and this stuff is a dream to work with. the glue holds rock solid and it shrinks way better than Monocoat. I bet you could cover a tennis ball with this stuff witout wrinkles.
Available online from Balsa USA http://www.balsastore.com/store/prod..._2_Meter_rolls |
ORIGINAL: Missileman Have you ever tried Solartex. It is a fabric iron on covering. I just got done covering wings for a Norseman I am working on and this stuff is a dream to work with. the glue holds rock solid and it shrinks way better than Monocoat. I bet you could cover a tennis ball with this stuff witout wrinkles. Available online from Balsa USA http://www.balsastore.com/store/prod..._2_Meter_rolls |
Try Ceconite, the lightest weight, it comes in several weights. Aircraft Spruce and Specialties is a source. Goes on very well but you need to use an adhesive or nitrate dope to attach it. Shrinks great and makes a beautiful finish. Also comes in as long a roll as you want and I think it is either 4 or 5 feet wide. Check out their web site.
You can paint Solartex, in fact that I will be painting my model with Butyrate dope, but polyurathane based paints will work just as well.
PS: I just remembered a while back I called Balsa USA and they paint their Solartex covered models with Latex house paint. I would go that route but I don't need a quart of paint and that is the smallest amount I can get. |
Another question: I've heard that Koverall is good but you have to apply the adhesive to the airframe first. Compared to Solartex which of the two is best and more natural looking after painting? By-the-way it is a Kadet Mark II I will be covering (in the manual's prototype it is covered with silkspan)
P.S: Missileman, why would Balsa USA paint their planes with Latex paint? Latex is not fuelproof. |
I don't know, they told me it was.
I have a Kadet MK II in my hangar right now. Great flying airplane. |
OK, so I am thinking of going with Solartex antique. Now I have a final question: Will painting the Solartex with Rustoleum or auto paint (both said to be fuelproof) be enough? Or will something have to be painted over the paint?
Not sure that rustoleum is fuel proof. auto paint is.
With the Mark II covered with Solartex and painted by hand, will a GMS2000 .32 be enough power? If not what should I put in it?
ORIGINAL: goirish Not sure that rustoleum is fuel proof. auto paint is. |
I think that is a good idea. I had a bad experience with rustoleum
I have an OS 40fp in mine (about the same as the OS 40LA) and it has power to spare. I would think the 32 will fly Ok, it is in the middle of the range recommended.
ORIGINAL: Missileman I have an OS 40fp in mine (about the same as the OS 40LA) and it has power to spare. I would think the 32 will fly Ok, it is in the middle of the range recommended. And using auto paint is it best to thin it first (what percentage) or use it straight out of the can? |
If it is enamel==mix 25% thinner to 75% paint. If it is lacquer 50-50. That is if you are spraying.
ORIGINAL: goirish If it is enamel==mix 25% thinner to 75% paint. If it is lacquer 50-50. That is if you are spraying. |
Probably laquer but it is hard to brush as it wants to get tacky quite quickly. I would probably use more thinner in the enamel than the 25% if you are going to brush. That way it will have a chance to flow to cover the brush marks.--Do use a good brush.
What do you think of Midwest Aerogloss? How many 3.5 oz jars of dope and thinner would I need to completely do the Mark II? What paint would be best for the cowl?
Will Monokote trim set properly over dope? |
http://www.coverite.com/covering/covq1000.html
Dealers in your general area http://www.gpdealera.com/cgi-bin/WCA56910BP.pgm click on an underlined store name for their web site. |
This discussion has really moved out of the realm of the beginner's forum. The type of questions you are asking would probably be better answered in the Kit Building forum. I'm going to move this thread to that forum.
Ken |
| All times are GMT -8. The time now is 06:35 PM. |
