RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   DOH!! TopFlite Screw up!! (https://www.rcuniverse.com/forum/kit-building-121/725076-doh-topflite-screw-up.html)
Shok 04-26-2003 08:04 PM
Ok, man I just made the stupidest screwed up my TF P-39.
Need opinions on what to do here.
I was busy talking on the phone and framing up the left wing panel (on the right in the pics) and totally messed it up. By the way, the panels are not joined yet, thank goodness.
I started the spar web one rib too far down. I started it on the #2 rib instead of the number 1 rib.
This is what happens when you havent built a wood kit in 8 years I guess.
Take a look at the pics below to see the screw up.....any ideas on what to do?
Or do I need to just re-order that whole panel and start from scratch from TF?
http://alphaworx.com/tf1.jpg
http://alphaworx.com/tf2.jpg
http://alphaworx.com/tf3.jpg
Rocketman612 04-26-2003 08:32 PM
Shok,
I do think you can save the wing.
Looks like you used CA if so patiently dissolve the CA joints with acetone and free them with your X-acto 11 blade. If the spar web is undamaged (doubt) then reuse. If the spar web is damaged then try to keep its outline as intact as possible and cut a new one from stock balsa of the same thickness. You really need to go slow and not break any of the ribs while cleaning them up.
Wing was looking good otherwise. Good luck, Pete
CafeenMan 04-26-2003 10:59 PM
I would basically scrap the web. I wouldn't use any kind of debonder. Just cut it off between the ribs and leave a little still attached. Then using a small, flat block sand off the excess.
Also, CA is the perfect choice for making mistakes like this. No chance to correct it. I suggest you consider using a good carpenter's glue in the future.
4*60 04-27-2003 12:03 AM
Cut the number 2 rib front part out. Put a web in, in front of the one that is there, right to the center. Add a section behind it where the web should have been. Put the rib front section back in and carry on. Or you can cut the rib at the rear also and add some support there across. Who's gonna know! Should be strong.
Shortman 04-27-2003 02:09 AM
If I were you I would probably buy another kit or reorder the wing panel.... It might be cheaper to just buy the kit. That way, as long as you don't mess up on the wing, you will have spare parts for the rest of the plane.
Shok 05-07-2003 03:38 PM
Ok I went ahead and ordered another wing panel from GP, got it in 2 days!
The new wing came out good, just about time to join them.
Things are moving along, but I have to say, man the P-39 instructions really crap out once you get near the final building stages.
It starts off great with lots of photos, then after you mount the engine....it basically just says finish it up.
I have tons of parts left.
Anyone built this plane?
Whats the big cardboard tube for???
firefighter56 05-10-2003 10:45 PM
covering
I saw on another post that you plan to glass your P-39. I am just starting mine and I want to glass mine too. What weight of glass are you going to use, and how are you going to treat the rudder and elevator?
Looks to me that they are supposed to be silk and dope. I don't want to go that route.
The tube is to run the aileron ext. though the wing. I haven't got that far yet.
Shok 05-10-2003 11:54 PM
Actually I just found out the tube is to put between the wing sheeting and the ribs for the wing bolt guide.
Im using 3/4oz cloth on the fuse and and wing.
Im mixing up zpoxy finishing resin with a bit of alcohol and painting it on the ailerons, elevators and rudder.
Then im mixing primer with microbaloons and coating them and lightly sanding.....I will do that a few times then paint them.
firefighter56 05-13-2003 05:35 PM
covering
I must not be understanding something, the elev. and rudders are not skinned w/balsa. how do you cover them before the resin?
CafeenMan 05-13-2003 05:45 PM
I'm not real familiar with the P-39. Were the flight surfaces maybe fabric covered? If not then you'll have to sheet them. Check the plans and instructions carefully. It has to indicate what to do somewhere.
Shok 05-13-2003 05:49 PM
My plan was to leave the control surfaces like they are after being built...no covering of any sort.
Just brushing on finishing epoxy, priming and painting....thats the plan at least.
firefighter56 05-16-2003 01:11 AM
tail feather
I've given this some thought, the real plane had fabric tail surfaces. I think I will just cover the elev. and rudder with monocoat and scuff it up and paint it like the rest of the plane. That way it will keep the fabric look and for the rest of the plane using glass and resin. What do you think?
Shok 05-16-2003 03:58 AM
good point, I may do the same, I'm still on the fence though. I think I can make it look nice with it just epoxied and painted, we will see. But monokote and paint seems simple enough.
Lukepiestalker 05-16-2003 11:33 PM
Try using solartex on the control surfaces ,it looks wright and takes paint well.
Colin.
