RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   SIG 1/5 scale cub (https://www.rcuniverse.com/forum/kit-building-121/7492666-sig-1-5-scale-cub.html)
PetesCub 05-13-2008 07:02 PM
SIG 1/5 scale cub
Putting together the second (right) wing I have noticed that I have made a mistake on the leading edge of the first wing I built (left). I failed to trim down the leading edge sheet so ithe trailing edge would rest halfway along the main spar. Instead, I simply glued in the entire 3" sheet which overshoots the main spar approx. .50 inches or so. I ignorantly went ahead and finished the wing (including installing all the rib cap strips etc.), and did not notice this mistake until I started building the second wing. My question is this: Will it be OK to simply build the other wing the same way? The only trouble I can imagine is a small amount of extra weight (I figure very nominal). Being new to this I wanted to appeal to someone who may know this model and whether their are any future problems that I can't anticipate. Thanks for any help you may offer, Pete[/size]
rogsteele 05-13-2008 07:11 PM
RE: SIG 1/5 scale cub
If you can not fix the first wing, by all means build the second too match the first, it should fly good, I finised one about a year ago and they are great flyers, they build light so I doubt if that .50 extra on the wing sheeting will matter
khodges 05-13-2008 10:13 PM
It won't make any difference at all, just build the second wing the same way.
tailskid 05-13-2008 10:14 PM
If the two wings match....that's all that counts - after all it IS a Cub :)
