No Control Horns
I'm Building a P-47 60 size. Would like to make it as scale as possible, Is there any way to move the control surfaces with out using horns or pushrods on the outside of the airplane? Maybe something on the interior of the plane? Don't know but it would be clean looking..
No Control Horns
Try this:
http://www.proptwisters.org/rds2/ or u can get Beckman Concealed Actuators from here: http://www.hobby-lobby.com/balllink.htm |
No Control Horns
Mikechri the tourque rod system will work fine but there is a little easier way to do this and that is to make like a crank end on a wire that will be inserted in the proper hole of the servo arm. then make a couple of bearing plates then to the control serface. The servo will lay flate in the thickest part of the wing facing the control serface. This will work just fine I'm doing the same thing on my 1/5 scale P-47. Have already done it to the tail feathers and they are working just fine and look good too.
| All times are GMT -8. The time now is 09:59 AM. |
