RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Please Help!!!!!!!! (https://www.rcuniverse.com/forum/kit-building-121/793796-please-help.html)
turissa 05-22-2003 12:50 PM
Please Help!!!!!!!!
I HAVE BEEN RETIRED FROM THE HOBBI FOR THE LAST TWO YEARS,SO NOW I'M TRYING TO DO MY COME BACK IN TO FLYING,SO I'M PUTTING MY PLANES TOGETHER,AND NEED TO CONTINUE SOME UNFINISHED PROYECTS SO HERE IS MY QUESTION:
BEFORE RETIERING(TWO YEARS A GO) I BOUGHT FROM TOWER HOBBIES SOME CA GLUE( IDONT REMEMBER THE BRAND) AND EPOXI,WELL THE CA BOTTLE HAVE A DATE ON IT; IT WILL BE THE EXPIRATION DATE?
SHOULD I USE IT?
DO THE GLUE GET BAD WITH TIME?
IT HAVE BEEN STORED IN THE CLOSSET WITH MY PLANES.
OK FRIENDS I NEED YOU PROFESIONAL ADVICE PLEASE HELP!!!!!!
REGARDS ISSA
GOD BLESS YOU
JOHN 3.16
LesUyeda 05-22-2003 01:23 PM
Please Help!!!!!!!!
If it hasn't hardened up in the bottle, it will be OK.
Les
tonyc 05-22-2003 01:28 PM
Please Help!!!!!!!!
You can always test it on scrap wood. If the glue holds and the wood breaks you will be fine.
If in doubt, throw it out! Glue is the cheapest part of building a plane.
tonyc
tailskid 05-23-2003 06:33 PM
Please Help!!!!!!!!
The 'thin' variety starts to get 'stringy' as it starts going bad. If it leaves a 'tail' when you pull away from the surface you are gluing, it going, going, going.....BAD. replace it!
Jerry
William Robison 05-23-2003 07:01 PM
Please Help!!!!!!!!
turissa:
Test the epoxy on a scrap, when it goes bad it's obvious.
THis IS NOT TRUE with CA. It can still be nicely liquid, but not make a good bond. Test it also, if the joint seems strong use it only in a location that is not critical, buy fresh for joints that need full strength.
Bill.
PS: You can store CA indefinitely in your refrigerator, but only in new, sealed bottles. Don't freeze it, and be sure to let it come up to room temperature before you open the bottle. wr.
Jesse-RCU 05-24-2003 04:24 AM
Please Help!!!!!!!!
If i was you, i wouldn't use the CA. CA's do go bad. Spend the money, get a new bottle and be sure about it.
DBCherry 05-24-2003 10:03 PM
Please Help!!!!!!!!
I agree with buying new. Why risk a plane for $10 or $15 worth of glue?
Oh, and please turn of your Caps Lock. All capital letters is considered rude (like SHOUTING), and it's harder to read.
Dennis-
