TF Giant P-47D Elevator leading edge
While reading the instructions to the P-47 it states on on number 21: "If you haven’t done so already, trim the top edge of the elevator LE spars even with the top of the
ribs. Glue the top elevator skins to the top of the elevators. As shown on the cross section on the plan, the beveled edges are on the inside." This all seems to make sense. Sand the leading Edge spars even with the ribs. Except for one thing that is getting me a little confused. The elevatore LE spars have a notch and the far end of them on top. It is where you put the inner root blocks of wood if that makes sense. Do I sand those down as well even with the ribs or I am just leaving them alone and sanding down the rest of the LE spar with the ribs? Because if I just sand the elevator LE spar except for the area with the raised notch, when I put the sheeting down on the elevator that spot will not be even at all. |
| All times are GMT -8. The time now is 07:04 PM. |
