RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   HELP....Whats this plane called (https://www.rcuniverse.com/forum/kit-building-121/8433970-help-whats-plane-called.html)
snap it 02-03-2009 12:54 PM
OK....This is a question for some of the people who have been in this hobby for 15-20 years. When I was a kid I built a kit that Tower sold. This was a fun flyer type plane with a dimond shaped airfoil. It had a fiberglass tube fuse (3/8-1/2) round that went through the wing so the tail stabs would glue to. This tube type fuse was also glued to the motor mount. I want to say it was a .25 size plane and had wire landing gear at each wing tip that scewed into the spar and went to the ground. May have had a wire in the rear to act as tail gear. I called Tower and no one could remember it.
Do any of you remember this plane and who made it? I would like to find a set of plans for it, hope someone would have a set in there basement or somewhere.
John
planebuilder66 02-03-2009 01:11 PM
RE: HELP....Whats this plane called
Let me look in an old catalog, it's made by tower or just sold by tower?
snap it 02-03-2009 01:23 PM
It was sold by Tower and may have been made by Great Planes...I think....
If I remember it was in the back of there book in the black and white pages.
planebuilder66 02-03-2009 01:40 PM
1 Attachment(s)
Does this ring a bell? Or should I keep digging?
planebuilder66 02-03-2009 01:48 PM
wow, I didn't read that right, the only plane I know of that has wheels in the tips of the wing was made by cressline models, and it was called the Quickie, they also made the long-ez as well.
snap it 02-03-2009 01:48 PM
Nope, it was more of a fun flyer. Big dimond shaped airfoil. The fuse was just a small tube from the wing to the tail.
John
snap it 02-03-2009 01:51 PM
ORIGINAL: planebuilder66
No wheels on the wing tips. Just bent wire on the wing tips that scewed into the spar and went to the ground. Where the wire meets the ground it wast bent so it would drag.
planebuilder66 02-03-2009 01:53 PM
I know what your talking about now, it was a thick straight chord wing, and it had a F/G tube that ran through it to the tail, and a mount plate in front for the engine, kinda like a pre ugly stick, but with out the box fuselage, just a F/G tube to tie the whole thing together.
planebuilder66 02-03-2009 02:00 PM
It wasn't an aerobat by duraplane, but very similar.
planebuilder66 02-03-2009 02:02 PM
J&C Hobbies FUN-BAT ARF,..... let me post the pic.
snap it 02-03-2009 02:02 PM
:D Thats it. I would love to build and fly it again, just need to find out what its called and where I can get some plans;) Maybe this time it would last longer then the first one:(
snap it 02-03-2009 02:05 PM
It wasn't an ARF.....I remember building it. I wish I could remember things!!!!
planebuilder66 02-03-2009 02:05 PM
1 Attachment(s)
Here?
snap it 02-03-2009 02:15 PM
Nope, not it. Was more of a fun flyer not a combat plane. Fuse was a bit longer also.
John
planebuilder66 02-03-2009 02:27 PM
Yeah, I'll look deeper, have to figure out where the older catalogs I are.
snap it 02-03-2009 02:40 PM
Thinking about it, it would be early to mid 90's
Ram-bro 02-03-2009 07:27 PM
TADPOLE, I scatch builtone before.....the design I believe was in RCM Magazine
TLH101 02-03-2009 07:41 PM
Diamond Unlimited. It was bult by Diamond R/C, the same company that built the Diamond Dust.
http://www.diamonddustrc.com/
snap it 02-03-2009 07:51 PM
That looks like it, but not it. The wing did not taper down like that at the tips. The diamonds where larger. The ailerons where also larger, in the 4-5 inch range and did not taper.
I wish I could think of it[:@]
snap it 02-04-2009 10:49 PM
Anyone find a Tower book from around 1990-1995ish? Its got to be out there:D
FentonFlyer 02-05-2009 07:25 AM
From the sounds of it, it's an old competition fun fly plane. Diamond airfoil, tube fuse, barn door ailerons, wing tip skids. I know exactly the plane you're describing since an old club member used to fly one. Just cant think of the name. Try googlin' "competition fun fly"
