RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   GP Easy Sport 40: engine thrust (https://www.rcuniverse.com/forum/kit-building-121/856196-gp-easy-sport-40-engine-thrust.html)
Dazzler_BE 06-12-2003 11:12 AM
I'm currently building this kit, and I'm mounting an OS .46FX engine in it.
Now, the firewall doesn't seem to have any right thrust build-in, so, is this not required for this plane, or would I benefit from giving it a slight degree of right thrust anyway ?
MinnFlyer 06-12-2003 12:40 PM
1 Attachment(s)
It's not critical, but it wouldn't hurt if you want to do it. The easiest way is to build it as per the instructions, then, once it's finished, add 1 or 2 washers to each of the left engine mount screws between the mount and the firewall.
Dazzler_BE 06-12-2003 02:06 PM
Thanks MinnFlyer!
Do you have a picture for everything ? Or do you just make them up on request ? Great going!
I already build to fuselage & firewall as per the plans, so the washer thingie is the only way I could go... I guess a little experimenting wouldn't hurt right?
