Wing dowel - is this the right thing?
Hello,
I realize that this is a stupid question but I rather ask than to buy the wrong thing. I am looking for 1/4" wing dowel and I am not able to find it localy in my hobby shop - they told me to go to Lowes but they don't have the proper size... So I found Birch dowel at Hobby-Lobby (http://www.hobby-lobby.com/1_4x36_b...l_2718_prd1.htm) but I want to make sure that it is the right kind before to place my order. I want the really hard wood since it is to secure my wings to the fuselage. Thank you for your help, Le fou |
RE: Wing dowel - is this the right thing?
Hey Le fou
you might also try the local hardware store. I can usually get 1/4 dowel from Ace or True Value. I can usually find it as well at Lowes/Home Depot. Doug |
And yes, the birch will work just fine
a 1/4" birch dowel from Lowe's will work fine. Only question is making sure it is sufficiently sized for the airplane you intend to use it on.
Cheers, |
right... What sort of model is this going on?
I've used scrap carbon fiber pushrods filled with epoxy mixed with microballons... I save the scrap ends whenever I use CF pushrods... |
what are microballons?
http://www3.omnimodels.com/cgi-bin/w...I=TOPR1090&P=0
They can be ground glass or plastic |
I'm not even sure what the different dowel wood is that comes in kits these days but I just buy my dowel wood from any hardware store. I use two dowels on my planes and it's usually 1/4 or 5/16. So far no dowel has ever broken.
ORIGINAL: wzak29 what are microballons? |
| All times are GMT -8. The time now is 02:22 PM. |
