RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   probond wing sheeting (https://www.rcuniverse.com/forum/kit-building-121/858681-probond-wing-sheeting.html)
fibchem 06-13-2003 05:06 AM
i am going to sheet the cores of a 35% edge . I am planning on using probond and a vac bag system will it work doing it this way. i need some tips or is there a better way
ml3456 06-13-2003 12:47 PM
This works great. I just did this for the first time and was no problem! Do a search and you will find lots of articles how to do it. Put it on thin, and no need to glue the sheets together. Just edge them. This stuff can get heavy. I put it on with a notched trowel the first time. Was too much. Didn't effect the outcome, but when I cut the elevators out, you could see the probond between the foam beads from one surface to the other!
mark
Flypaper 2 06-13-2003 01:08 PM
Most of the added weight is in the glue so I use a sawtooth pattern with a glue syringe When you think of it, a built up wing has 2,3 or 4in. between the rib glue lines. Havn't had a failure yet.
