RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   wing rib slots (https://www.rcuniverse.com/forum/kit-building-121/8590412-wing-rib-slots.html)
j6161 03-18-2009 09:36 AM
wing rib slots
What is the best way to slot wing ribs for serov wire
MinnFlyer 03-18-2009 09:48 AM
RE: wing rib slots
X-Acto knife
j6161 03-18-2009 10:01 AM
RE: wing rib slots
should they be slots or round holes which is stronger
Live Wire 03-18-2009 10:04 AM
RE: wing rib slots
Depends on if you are building the plane, already assembled,and the size. I use a hole saw width an extension. Then insert paper tubes.
MinnFlyer 03-18-2009 10:10 AM
RE: wing rib slots
ORIGINAL: j6161
It really doesn't matter. Ribs are "Shape Holders" and are exposed to very little stress. You can hack them up pretty badly and they will still do their job.
