Need Lanier Pro-Cub help
I'm hoping to hear from someone that has had experience with the Lanier Pro-Cub 40 kit. Irecently bought one that is RTF minus the receiver and battery and unfortunately I didn't get the plans with it. What I need is the CG to balance it properly. If someone reads thisthat has a set of plans that they would want to sell or donate, or a copy or photo of the plansI would greatly appreciate hearing from them! I've searched the web and haven't found anything except a PDFof the building instructions.
Thanks in advance, Bob |
RE: Need Lanier Pro-Cub help
Bob,
A Cub is a Cub, balance the plane at 30% back from the leading edge. That is a good place to start. Anthony |
1 Attachment(s)
Hi Anthony,
Thank you for your input and advise,I'm a little doubtful that it applies to this particular Cub. This one is a profile/funfly model and has a HUGE wing cord and the ailerons are also oversized (to say the least), about 2 inches wide. Picture attached. Thanks again, Bob |
Bob,
I am guessing you will still find the balance is right around the 30% mark. Anthony |
| All times are GMT -8. The time now is 10:54 AM. |
