RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   4* canopy UGH!!!! (https://www.rcuniverse.com/forum/kit-building-121/89192-4%2A-canopy-ugh.html)
DanNJ 03-28-2002 12:48 AM
4* canopy UGH!!!!
Hi Any idea's on what to do with that ugly canopy that comes with the 4*40/60?? Any tips on building either of these?
Thanks Dan
punkey71 03-28-2002 01:27 AM
suggestions...
Take the canopy and toss it in the trash can.....
Call Bruce Tharpe and get a canopy for a Venture 60. It's lower profile (similar to an extra) is much nicer imho. There's links to contact him at www.venture60.com
As for mods...here's what I did.
1. Rudder - added a tapered extension 1" at the top down
to 2" at the bottom.
2. Shorten the wing by one bay each side.
3. Sheet the leading edge to first spar if you fly off a grass
field to prevent lots of holes in your covering.
4. Order some wheel pants - I got a set from a Venture 60 while
I was ordering the canopy. Again, looks nicer in my opinion.
It's a blast to fly...you'll surely love it.
Best,
Harold
TCBLightning 03-28-2002 12:18 PM
4* canopy UGH!!!!
1 Attachment(s)
I had originally installed the stock canopy but cut it down so it wasn't so funky looking.
The nose was tapered after seeing an article in RCM a couple years ago.
winship 03-28-2002 01:44 PM
4* canopy UGH!!!!
Ditto on cutting the canopy down. I didn't like the way the canopy looked so I trimmed it from the back and bottom to get a better profile. Nothing to loose so start trimming untill you get what you like.
Winship
DanNJ 03-29-2002 12:18 AM
4* canopy
1 Attachment(s)
Hi..Thanks for your fast replies..I was also thinking about trimming the canopy..
Harold.. I met Buce Tharpe at the WRAM show.this past Feb. The Venture 60 is on my "to build" list.
The 4* will be my 1st attempt to fly a tail dragger..I am presently trainning with a Sig MidStar which Buce designed. Flys much better then my old trainer.
Emissions 03-29-2002 12:38 AM
4* canopy UGH!!!!
I heard somewhere you can turn the canopy backwards and trim it to fit like that. Makes a much more sleaker profile.
punkey71 03-29-2002 01:46 AM
Bruce..
Bruce is a stand up guy....a pleasure to deal with.
Best,
Harold
