RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Hobby knife cap issues (https://www.rcuniverse.com/forum/kit-building-121/9303566-hobby-knife-cap-issues.html)
Alex7403 12-04-2009 03:18 PM
I have several perfectly good hobby knives that I’m gonna throw away just because they are missing their caps.
If I’ll not throw them away I’ll keep wounding my self hitting them with my fingers.
My tools drawer is like a hole with lurking scorpions because of these knives.
Do you have some idea how to secure or replace these caps?
Alex
Greg Wright 12-04-2009 03:30 PM
RE: Hobby knife cap issues
Why don't you just take the blade out, and reinsert it into the holder up-side down so that the blade part is not exposed to cut your fingers.
Alex7403 12-04-2009 03:33 PM
hmmm never thought of that, thanks.
Revy 12-04-2009 03:39 PM
Get a blue styrofoam chunk and stab them in when not in use. They sit in a neat row on yer bench and stay out of harms way.
Super_Dave 12-04-2009 03:48 PM
Some pen caps fit very well depending on the hobby knife.
huck1199 12-04-2009 03:52 PM
I didn't hurt my fingers, but my experience was also painfull until I made sure to push on the clear plastic cap each time i was finished using the knife. It took two instances of the knife rolling off the bench and sticking in my foot for me to remember to put the cap on. It seems that more times than not, the knife will fall with the blade pointing down.
Alex7403 12-04-2009 04:01 PM
Yes so far it missed my feet while falling but I cannot count on that miracle, it does fall blade pointing down.
I thought of gluing the cap with a wire strip but its no comfortable to work with it this way.
WacoNut 12-04-2009 04:11 PM
LMAO,
This made me remember when I was a kid building a Comet kit and I was sitting at my work bench looking all over for my x-acto knife when I finally found it sticking up out of my leg, never even felt it stick me and it was buried to the handle.
I have to admit to this day I never use the caps, I put the knife nose down into a cup.
Later!!
Anthony
Scar 12-04-2009 04:34 PM
Alex,
If you're like me, you have one of those tool holders on the wall, behind your work bench. Get some 3/8" surgical tubing from Ace Hardware. Cut a 4" segment for each knife with no cap. Put fish line through the hose, tie it to the hose and to the tool holder.
Now slide the knife into the hose, and let it hang. You'll never lose that hose.
Best wishes,
Dave Olson
mclina 12-04-2009 04:53 PM
I just leave them sticking vertically out of the ceiling tile on my workbench.
MinnFlyer 12-04-2009 04:59 PM
1 Attachment(s)
I always wrap a piece of tape around the handle and stick the two ends of the tape together to make a little "Flag" that keeps the knife from rolling
Alex7403 12-04-2009 05:11 PM
Thanks these are good ideas to make it stop rolling and be more noticeable.
daveopam 12-04-2009 06:00 PM
I use ear plugs for a cap. The ones that your roll up and then they expand in your ear. They are about 1/2" around and 1" long. Lot's of other good ideas here.
David
carrellh 12-05-2009 09:47 AM
1 Attachment(s)
When I started shopping for tools I didn't like the standard hobby knives very much because of the totally round handle.
I saw the 'Excel' brand at the hobby shop and noticed it has a hex shape at the end of the handle so it does not roll. I bought the Excel.
I've since seen other brands with the same design. The Revell brand has one for $2.49 which is the one in the picture. It is currently out of stock at Tower
http://www3.towerhobbies.com/cgi-bin...?&I=LXWBJ9&P=0
A slightly more expensive one, with soft grip, is in stock
http://www3.towerhobbies.com/cgi-bin...?&I=LXWBJ7&P=0
It appears to be identical to the Excel.
dbacque 12-05-2009 12:52 PM
A short length of plastic tube makes a good cap. There are a variety of sizes available at your local hardware store. Just bring your knife to find the right fit. Leave the blade at home, it's heck in your pocket!
Dave
Hemikiller 12-05-2009 01:35 PM
I usually reverse the blade, but have also used a chunk of soft balsa, wine corks and pen caps. To solve the rolling knife turned javelin problem, you can glue a balsa stick to the side, drill through the end and insert a screw, or get some of the triangular pencil grips from Staple/Office Max/etc
http://www.amazon.com/Maxi-Aids-Tria...bxgy_hpc_img_b
huck1199 12-06-2009 02:28 AM
To stop the rolling when the cap is not on I have double twisted a small rubber band near the end of the handle.
kdc 12-06-2009 11:28 AM
Consider getting a Swann Morton 'Retractaway ' holder which takes scalpel blades (10A etc ) www.craftknives.co.uk/products/retractaway.html or the USA agent http://www.cincinnatisurgical.com/li...&item=crhandle This retracts the blade into the handle yet holds it as firm as a normal scalpel without play. Not much more cost than a normal scalpel, and the blades are the super sharp type not the hobby knife type.
Alex7403 12-06-2009 02:49 PM
thanks, that Retractaway looks like what I need.
foodstick 12-06-2009 03:31 PM
I really like the sticking it into a piece of foam best personally, plus it makes it easier to find once you get used to it. The non roll idea can pay off if you have a slanted artisit table...
