RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Falcon III (https://www.rcuniverse.com/forum/kit-building-121/9333641-falcon-iii.html)
evaristus 12-15-2009 05:55 PM
Falcon III
Im starting to build a falcon III kit, and been thinking in removing diehdral, but I can not figure out how to fit the diehdral braces on the wing. Will I need to make new braces?, how much diehdral will you recommend to make the plane a bit more aerobatic but still stable?.
Thank you for your counsel
AllTheGoodNamesAreTaken 12-15-2009 06:08 PM
RE: Falcon III
Make the wing flat. Cut new braces from your scrap box.
evaristus 12-15-2009 07:21 PM
RE: Falcon III
Ill try
evaristus 12-15-2009 07:23 PM
RE: Falcon III
evaristus 12-15-2009 09:45 PM
RE: Falcon III
first trouble, the stabilizer ribs rear end is not at 90 deg. so they almost dont make contact with TE.
Any suggestions?
MinnFlyer 12-16-2009 12:52 PM
RE: Falcon III
Can you post a pic?
evaristus 12-16-2009 04:41 PM
RE: Falcon III
I got it , one of the instructions advices to shape the TE flush with stab stock (angled control surface), after that youre supposed to stand the TE on this side only that instructions dont tell you that, I already glued it.
Sorry for the double post, Ill do a building thread from here
evaristus 12-16-2009 09:41 PM
RE: Falcon III
1 Attachment(s)
Finally made the stab. , the ruder“s glue is still setting
The first officer is showing
evaristus 12-21-2009 12:57 AM
RE: Falcon III
Wing halves glued and ready to join, Ill go with 0 diehdral, had to make a 1/8 diedral brace, completely horizontal, I have never built no diehdral planes so Ill see how this one behaves.
pics tomorrow
