Pushrods
How can I make or what should I use to get good 90º angles to connect the pushrods to the servo arm.
Pushrods
jucava,
I am assuming you mean 90 degree bends for "Z" bends? I use "Z" bend pliers from Tower. http://www2.towerhobbies.com/cgi-bin...?&I=LXXC81&P=7 John |
Pushrods
I just use a pair of needle nose pliers.
Pushrods
If you're making a z-bend, use the z-bend plier or you could use the wire bending die from Higley. The die comes in various sizes for different size rods but you could buy a set which is cheaper.
Pushrods
Is there some reason you are committed to Z-bends? I never use them but prefer clevises or ball-links. The DuBro ball links are low friction, non-binding and have absolutely no play. Just screw the ball into the servo arm and snap on the nylon coupler socket.
Dave Segal |
Pushrods
Z bends are quick and easy. Only one moving part so less likely to break (and if it does, it will probably do it when making the z bend, not while flying your £1000 plane).
Pushrods
You got a plane that weighs a thousand pounds? :D
Pushrods
1 Attachment(s)
You got a plane that weighs a thousand pounds? You can also use standard pliers to make a "Z" bend. It takes two bends and a twist though. ;) Dennis- |
| All times are GMT -8. The time now is 03:29 PM. |
