RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   4*40 Help (https://www.rcuniverse.com/forum/kit-building-121/972580-4%2A40-help.html)
FatCat 07-19-2003 02:07 PM
4*40 Help
Hey guys, I am building a 4*40 as my first kit and have a quick question. I am at the stage where I have the fuselage mocked up with rubber bands and the frames installed. It says to use a medium ca in the corners to start with... Making sure everything is aligned, then use more ca to permanatly fasten all the pieces. The question I have is do I take the frames out one at a time to completely get the ca in the grooves? Or do I leave them in and just lay a bead along the edges?
I never thought building could be so much fun!!
Oregon Craig 07-19-2003 02:35 PM
4*40 Help
I left it all assembled and ran a "bead" along the joints. You will find that with other than very thick CA, it will not form an actual "bead", but that it will run into the joints. Just make sure to hit all sides of every joint as much as you possibly can. And make sure it is nice and straight! Have more fun!
Craig.
DaveB 07-19-2003 09:34 PM
4*40 Help
I agree with Craig. Apply the CA glue with the formers in place. Later with the rubber bands removed, you should go over the joints as needed.
DaveB
AdrianM 07-19-2003 09:56 PM
4*40 Help
I did the same as above just be sure to use med or thin CA.
FatCat 07-20-2003 11:29 AM
4*40 Help
Thanks guys! I am going to use some thin CA, the go over it with some medium after the rubber bands are off. I can't get over how helpfull some of the people are on here! Thanks again.
Hurricane90 07-21-2003 04:45 PM
4*40 Help
Use medium CA first. This will buy you a few seconds to check the alignment after each application of glue. This will set up too fast. You really want that fuse as straight as you can get it.
Hurricane90 07-21-2003 04:46 PM
4*40 Help
Oops I made a typo. I meant to say "Thin will set up too fast" instead of "This".
