RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Paint (https://www.rcuniverse.com/forum/kit-building-121/9792229-paint.html)
wattmeter 06-09-2010 02:21 PM
Paint
Need a little help, I'v built a Sig Astro Hog and will be covering it with Sig coverall.
What would be the best paint to use? and what would be the best way to Fuel Proof it?
wattmeter
shd3920 06-09-2010 04:40 PM
RE: Paint
The best paint to use on these types of covering are always Butyrate dopes, I am doing one now with Brodak dope and silkspan. But even Rustoleum is fuelproof after a few weeks of curing. But I'd go with the dope finish.
Here it is
http://www.brodak.com/shop_productde...ProductID=6735
But you first need a few coats of this
http://www.brodak.com/shop_productde...ProductID=6796
Mixed 50/50 with this before painting, but use 1 coat full-strength on framework for the covering to adhere to. Unless you are ironing the covering on, in which case you just apply 2-3 coats of clear dope thinned 50/50 with thinner
http://www.brodak.com/shop_productde...ProductID=6803
wattmeter 06-09-2010 05:16 PM
RE: Paint
shd3920
If I read it right the paint is fuel proof so why the clear dope?:)
Do you like silkpan better than coverall? and do you spray or brush on you paint?
Sorry for all the questions but this new to me (coverall and dope,paint).
wattmeter:D
shd3920 06-09-2010 07:31 PM
RE: Paint
shd3920
For silkspan that I am using you have to put a coat or two of clear dope full strength on the framework. This acts as an adhesive so that the silkspan will stick when you put the top coats of thinned dope on the covering itself. The thinned dope on the covering softens the dope on the framework so that the covering adheres when it dries.
If you are going to iron the covering on you will still need a couple coats of clear dope mixed 50/50 with thinner to fill in the weave in the material so the colored dope will not pool inside.
Yes, personally I like the silkspan better, but it does have less strength than the coverall. And I brush the dope on. Dries very quick.
Although I will be powering it electric and I don't need the fuelproofing I love the silkspan and dope look.
wattmeter 06-09-2010 08:36 PM
RE: Paint
ORIGINAL: shd3920
shd3920
Thank for all the info.
wattmeter;)
