Oops, debonder question
I accidently CA'd a wing spar in upside down...:( Can debonder wick in between the ribs and the spar and free it or am I likely to make mess?
Thanks for any assistance... scott. |
I would try putting a little debonder on the CA without soaking the wood with it and taking a xacto to cut where the CA is. Make several passes over the CA'd area and try not to gouge the wood. I have had to do this before and it has worked for me.
Used a little debonder and some #11 work and got it off well enough that I think I can reuse the spar... Thanks for the info...
Scott. |
| All times are GMT -8. The time now is 08:28 PM. |
