OS 50 running probs!
CA
hi
i also have the cal 5 and although im not new to helicopters i am new to gas engines, ive jus delt with trexs etc and felt
it would be great to go bigger... im havin a problem thou... when i get my engine (OS 50 hyper) started and say idle for some time
wen i try and open it up.. instead of jus increasing it sounds like its spluttering and goin to die out! and like the glow plug isnt firing or something so i replaced it with a new one! wen i have my glow starter connected it seems to be fine but obviously u cant fly with a glow
starter sittin in there!!! theres not too much smoke either.... pls help me i really dont wanna mess this engine up!
CA
RE: OS 50 running probs!
main needle is about 1 and a half turns to the left like it says in the manual it should be...im running on cool power 15% at 20% oil or watever... if its rich then why aint there so much smoke?? thanks for trying to help me!
CA
thanks so much i just got my engine running now n seen the difference i guess it was running too rich! but hey i was following th OS manuals they said 1.5 turns! do u think if i have it at about 0.6 turn on my needle it will be bad for the engine or too lean?? it seems stable there and reacts well...?but i dont want to blow this 200$ engine
once again thanks so much for ur time...
CA
wow thanks man its running so well now!! it is almost at a full turn almost and theres no more raw gunk build up in my muffler when i tip it!
its also not too cool but not to hot after a good work out
i think i have it right hey>??????????????
thanks so much
thanks so much
