Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
Reload this Page >
who still owns a Nexus?
Kyosho Helicopters Discuss all Kyosho heli topics here.
Old 06-29-2007, 02:44 PM
ja29
Default who still owns a Nexus?
Hi guys. I own a Nexus 30 and my stock stock starter cone is shot. I have the an aluminum starter cone upgrade, but it doesn't fit properly. For the guys that have experienced this problem, how did you make the starter cone fit properly?
Old 07-05-2007, 02:59 AM
NikoBel
Default RE: who still owns a Nexus?
I am sorry I cannot answer your question (about fitting the aluminum cone) but I had the same problem (with plastic cones) and my solution was to replace it with a hex starter fitting.
Never had a problem since.
Regards.
Old 07-05-2007, 08:22 PM
ja29
I figured it out after I modified my aluminum cone. I just noticed that the part that the cone attachs to has a lot of play in it. Now I have to replace that part. I was suppose to remove that part replace it with the aluminum cone.
Old 07-07-2007, 04:28 AM
fstflyer
I think you have it right. I have a Nexus 30 ss with the 46 conversion and the starter cone was replaced with the aluminum one. Looks like you just unbolted the plastic one and bolted on the aluminum cone. Thinking about swithing to a hex starter though. Century sells the hex adapter and the wand in a kit. The wand has a one way bearing in it so it should make starting easier.
Old 07-09-2007, 11:51 AM
ja29
You are correct, I am waiting for Tower Hobbies to get it in stock. How well can you fly. Also, do you know if any clutches from other helicopters will fit the Nexus?
Old 07-26-2007, 05:19 AM
Mr Lee
Sorry to jack your thread here but I have a NEXUS 46 in mint condition but am not able to fly it due to the main gear having a chipped tooth!!
Does anyone know where I can order a main gear from?
Thanks and sorry
Old 07-27-2007, 01:07 AM
ja29
try Kyosho or Time tunnel.com
Old 07-30-2007, 11:22 AM
supergenius
ebay
Old 01-07-2008, 08:51 AM
joecarbery
i have 2 brand new ones never even been fired up..gonna this spring though...i like them alot..
Old 01-17-2008, 07:29 PM
RaceCraftRC
I proudle still have my nexus but i am running out of parts ebay is starting to get pricey i just don't want to retire her yet. AX
