Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
Reload this Page >
need help identifying kyosho heli.
Kyosho Helicopters Discuss all Kyosho heli topics here.
Old 01-09-2008, 05:00 PM
porter2udf
My Feedback: (13)
Default need help identifying kyosho heli.
Im having some trouble identifying a Kyosho heli. I need to know if it is a concept 30, dx,sx, sr or whatever it may be. Appears to be in excellent shape and runs great. motor is an os max 32 f that appears to be almost new condition with a load of compression. what are characteristics can I look for to make sure which one it is? It is a hex type starting only a starting hub was put on it. Im trying to locate main blades for it.
ID:	846731   Click image for larger version
ID:	846732   Click image for larger version
ID:	846733   Click image for larger version
ID:	846734   Click image for larger version
ID:	846735   Click image for larger version
Old 01-10-2008, 03:47 PM
chopper cook
Default RE: need help identifying kyosho heli.
Hi Elma, that Heli looks just like me Kyosho Concept 30DX.
ID:	847463   Click image for larger version
ID:	847464   Click image for larger version
Old 01-10-2008, 06:17 PM
BarracudaHockey
BarracudaHockey's Avatar
Yep its a DX, the cone start was stock.
Good luck finding parts or blades, they have a narrow root and you really cant put heavy blades as the grips have no thrust bearings. The original blades were made of foam.
try http://www.rcheliworks.com if Kyosho stocks it, Chris can get it but don't hold your breath.
Old 02-27-2008, 03:21 AM
KFK
Definately a concept 30, which one is hard to tell because the DX came with bushings where as the SE cam with bearings. Also note that is not the original tank. Good luck finding parts for her.
Old 02-28-2008, 11:09 PM
guitar
My Feedback: (-2)
it is a dx original dx heavy control paddles it has an sr main rotor head with nexus one piece main rotor grips. it has been upgraded with a se bearinged pitch slider . it has got a heli max muffler.I think i saw a header tank on it . other than that its fine but as you have already heard its tuff to find parts for it.
