Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
Reload this Page >
Heli motor v.s. airplane motor????
Kyosho Helicopters Discuss all Kyosho heli topics here.
Old 03-22-2008, 09:15 PM
kentoby
Default Heli motor v.s. airplane motor????
I just picked up a Caliber 5 that has an OS max 46 SF installed in it. After doing a bit of research, I discovered that this motor is listed under the AIRPLANE heading on the OS site. Is running this engine in my heli a problem or not??
KT
Old 03-23-2008, 09:01 PM
kentoby
Default RE: Heli motor v.s. airplane motor????
Somebody... Anybody know the difference between an Airplane Engine and a Helicopter OS engine?? Is there a difference or is this a marketing ploy???
KT
Old 03-24-2008, 05:24 AM
Cyberfyn
Cyberfyn's Avatar
The crankcases are the same but the heads are very different. The heli head need a bigger cooling area as they don't get the same amount of airflow. Does it have a round or square head like this?
OS heli engines have an H prefix in the name: http://www.osengines.com/engines/heli.html
So it sounds to me like someone has fitted a plane engine to it.... Not a great idea. I'd eBay the fitted engine and get a true heli variant.
Ian F.
Old 03-24-2008, 07:06 AM
kentoby
Yes, someone has gone the extra step and added a larger square heli head. Am I OK???
KT
Old 03-24-2008, 08:28 AM
fasterjman
Theres one other diference as well...The needle valves. There are 3 on a heli engine. A high, medium, and low speed. Jeff
Old 03-24-2008, 01:05 PM
-pkh-
-pkh-'s Avatar
Most heli engines are ringed engines.
EDIT - Looks like they made a heli version of that engine:
http://www.osengines.com/parts/xr15440.html
Old 03-24-2008, 02:54 PM
BarracudaHockey
BarracudaHockey's Avatar
The heli version has a shorter crankshaft, most helicopters won't fit a standard airplane engine. OS has (had i think) a 46 heli engine. The carb sucked, you could never get a good balance between the high and low end without the midrange being out of whack.
Some heli carbs have 3 needles, some have two, all depends on the engine.
