Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
Reload this Page >
tail servo getting really hot cant even touch it
Kyosho Helicopters Discuss all Kyosho heli topics here.
Old 06-24-2008, 03:51 PM
pool man
Default tail servo getting really hot cant even touch it
heli caliber 30 gyro 401 tail servo brand new 8717
the tail servo get so hot yuo cant touch it after a 10min flight gyro sen is at 70 on heading hold
why does it get so hot is this normal
Old 06-24-2008, 08:50 PM
cameltoe
Default RE: tail servo getting really hot cant even touch it
what battery voltage are you running for the electrics?
Old 06-25-2008, 06:28 AM
Cyberfyn
Cyberfyn's Avatar
Yeah, check that it's not a 4.8V only servo running on 6V
Also check that everything is free and easy. No binding.
Ian F.
Old 06-25-2008, 01:02 PM
BarracudaHockey
BarracudaHockey's Avatar
An 8717 on the tail??
Try a 9254
Usually that means too much gain though.
Old 06-25-2008, 06:54 PM
pool man
running 6v system,servo is 4.8 or 6v has no binding on the tail is gain same as gyro sen if so its at 70
Old 06-26-2008, 10:05 AM
machdiamond
machdiamond's Avatar
Not sure what a 8717 is but just check that you don't have the gyro set to DS (digital servo) if the 8717 is an analog servo it could be the higher pulse rate thats causing it to fry it's bits and have you set up the limit on the gyro so the pitch arm doesnt lock up?
Old 06-26-2008, 10:37 AM
pool man
the 8717 is a digital servo and the gyro limit is set to 70%
Old 06-26-2008, 10:58 AM
BarracudaHockey
Limit is too low, you need to have it atleast 100 (assuming we are talking about the gyro pot)
Gain is too high, turn it down to 55 or 60
Thats a digital servo and it will take 8v from a lipo so voltage isn't the problem.
Old 06-26-2008, 02:23 PM
machdiamond
Don't know bout that - your endpoint adjustment on the radio should be 100% - first turn the limit on the gyro to full, then give full rudder command in normal mode, then slowly decrease the limit until the pitch link reaches the limit of its travel on the tail shaft. unless your servo horn/pitch arm ratio is perfect it is unlikely that you will use "100" as a setting on the limit. Perhaps try to increase the delay setting on the gyro as the tail sensitivity could be quite low. Anyway I fly my Caliber 3 at 80% sens and it works fine.
Old 06-26-2008, 02:56 PM
BarracudaHockey
If your limit pot is under 100 then your servo arm is too long and should be shortened by one hole and the limit pot readjusted to it is at or slightly over 100.
You don't need delay with an 8717, its lightning fast, but I've never seen it used as a tail servo.
Old 06-26-2008, 03:21 PM
pool man
i shortened the servo arm and got the limit to 100 on gyro will try on sat thanks iused 8717 because its so fast thought faster was better. i dont have this problem on my trex 450
Old 07-04-2008, 05:29 AM
machdiamond
Have you opened the servo up? It might not have/enough grease on the gears which could load the motor...
