Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
Reload this Page >
Nexus 30 balance?
Kyosho Helicopters Discuss all Kyosho heli topics here.
Nexus 30 balance?
Old 12-31-2009, 03:29 AM
gauicanada
My Feedback: (12)
Default Nexus 30 balance?
I have a Nexus 30 that I am putting together and I noticed to get this to balance at the main shaft I need to load the front end with about a pound. It will make it slower and likely a little more stable but will it make a big difference on these helis. most other helis work much better when they are level when held at the mainshaft not tail or nose heavy. Will it work as well on the Nexus? Thanks
Old 12-31-2009, 09:23 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Nexus 30 balance?
All helis should balance at or just slightly ahead of the main shaft.
Get a bigger battery so you're atleast carrying usable weight.
You can fix it with trim but if you're trying to do any aerobatics it's going to cause problems and if you get it moving pretty good its going to want to ballon on you if you dont get it balanced right.
