Caliber 30 setup problems
Hello all, i bought a new caliber 30 and i setup it up according to the manual ( electronic mixing) when i hover and roll right or tail down it loses pitch and falls to the ground im using a JR XP652 controller and a jr G410T Gyro. please help me. i already had to fix my training gear 17 times so far due to this
Thank You, John |
RE: Caliber 30 setup problems
thats normal movement for the heli.when you pitch like you discribe the heli is going down ward,try to hover a little higher off the ground or dont make as large inputs to the stick on the radio
Thank you scott36 i'll give it a try and see if i can do better
if you are fairly new to learning to hover dont over do your limits to tho..have fun to and be safe, if you have a sim work on that some more as well.
| All times are GMT -8. The time now is 11:01 PM. |
