Go Back  RCU Forums > RC Helicopters > LMH Helicopter
Reload this Page >
how much slip should the tail gear be?
LMH Helicopter Discussion of all LMH helicopters both electric and glow.
Old 09-13-2004, 12:32 PM
jyc
jyc's Avatar
Default how much slip should the tail gear be?
Hi,
I have just finished the assembly of my 120 and noticed that the tail gear can slip if the tail blades are obstructed. Is this normal and how tight of a fit should the tail gear be? If the slip is too much, will it affect the tail authority?
Old 09-14-2004, 01:16 AM
KLRico
Default RE: how much slip should the tail gear be?
You should have no slipping. It's ok for the TR blades to have a little bit of spring to them because of the wire flexing. They shouldn't slip though. It will adversely affect yaw authority.
