LMH spare part
first of all, lets steam off a bit AAAAAARRRRRGGGGGGHHHHHHHHH
Just have a used corona and after testing a just saw the main shaft was bend. I ordered a crash kit, just in case .......
Last two weeks i had no time to work on the Helli. Today i finally had the time, and by accident i dropped the main shaft together with the almost balanced sub rotor attached on the floor. BEND AGAIN [X(]
So i have to order again...
QUESTION: Wat useful parts should i buy extra, remember i have already 99% of the crash kit at home ?
IL
Hi Mestdaght,
The Lite Machines Corona is a durable, nice flying model. In fact I liked it so much that I purchased another and now have two. However, there are some parts that can be improved. One of them is the main rotor shaft. I have in the past purchased replacement OEM main rotor shafts and to my surprise they were slightly bent! I have since installed an upgrade 5mm titanium shaft which I am very happy with. You may want to consider doing this upgrade. It is available from Ballistic Technology or Helihobby for $69.00 USD. Hope this helps.
Beaner
Beaner
