Go Back  RCU Forums > RC Helicopters > LMH Helicopter
LMH first flight >
LMH first flight
LMH Helicopter Discussion of all LMH helicopters both electric and glow.
LMH first flight
Old 01-25-2003, 09:31 PM
My Feedback: (7)
Default LMH first flight
so i took my used LMH out for a flight today and it was GREAT except this thing is hard to control. i bounced it about 5 times at least from 5 feet each time but nothing happened to it except the ziptie broke but i have one problem with it after 2 tanks the heli wont lift off. im using 15%CP could that b the problem ?? i have some baron left over will that work better ??
Old 01-25-2003, 09:58 PM
My Feedback: (7)
two more noob questions for the LMH. WHEre is the muffler ?? and how do i mount the skid to the body ?? the lmh body always tip sideway( i use zip tie)
Old 01-26-2003, 01:28 AM
sounds like you have as much flight time as me. if it runs but wont lift off it sounds like the clutch, ,put a screwdriver in the slots and spread it out so it makes more contact, the muffler is the carb/exhaust restrictor that your throttle is hooked to and the skid wires zip tie to the holes in the crutch , the frame,not the body.. Rog
you may be hitting the throttle too hard to take off if its leaning every time
Old 01-26-2003, 01:37 AM
My Feedback: (7)
sry i meant the frame but couldn't think of the word
but will he baron fuel help though ?
Old 01-26-2003, 02:41 AM
someone else on here says hes used cp %15 for 2 years and its been fine. I'm not familiar with baron fuel, but if its running with out power check the manual you may need to remove/add shims under the head/glow plug or replace glow plug, the manual has a good trouble shooting section in it......Rog
Old 01-26-2003, 04:24 AM
RobertWilliams's Avatar
I'm useing cool power 10% in mine, runs great....
Old 01-26-2003, 03:55 PM
My Feedback: (7)
so can lean engine caused the problem ???
Old 01-26-2003, 07:53 PM
Charlie's Avatar
I would say that you are to lean, but then agean you could be to rich. They can be very tricky to tune, just turn your needle a very little bit at a time, you will find the right spot. It is not your fuel, I have used 15%cp for over two years with mine.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
