Need help witha New Vmax-7
My Feedback: (24)
MI
Hi. I just got my new Vmax-7 Motor. But it has some sort of filter casing fitted it. however what screws into it cos I see a that it's threaded inside ????? ??? ????
RE: Need help witha New Vmax-7
Well, the venturi on that heli engine is simply that - a venturi. That particular engine doesn't have a typical throttled carb - it uses a muffler restrictor that is controlled like a carb throttle. The venturi on that engine has little thread like spaces in the venturi so the screen doesn't come out. Also, there is a needle valve located on the venturi.
