RCU Forums
-   LMH Helicopter (https://www.rcuniverse.com/forum/lmh-helicopter-216/)
-   -   lmh 110 norvel .74 clutch (https://www.rcuniverse.com/forum/lmh-helicopter-216/11217506-lmh-110-norvel-74-clutch.html)
jez33 09-04-2012 02:34 PM
hi
on my heli ( 110 lmh with vmax 74) the clutch is slipping now, where can i get a new one or any tips in reovating the one ive got ?
ive tried putting 2k metal putty on the inside of the bell which worked for aprox 15 mins flying then just started slipping again!
its a black nylon,plastic bell with alu shues which suprises me as the smaller clutch from the norvel vmax .61 is all alu bell n not plastic,nylon ect!
DeviousDave 02-03-2013 04:38 PM
RE: lmh 110 norvel .74 clutch
I haven't tried it myself but for a diesel conversion I am planning to alter the clutch by opening up the holes in the clutch. By doing this, the RPM that the clutch will engage will be lower (diesels have a lower RPM range) and will make the clutch grab harder at higher RPM. This might work for you too.
