RCU Forums
-   LMH Helicopter (https://www.rcuniverse.com/forum/lmh-helicopter-216/)
-   -   CLUCH (https://www.rcuniverse.com/forum/lmh-helicopter-216/1833682-cluch.html)
Joe K 05-21-2004 04:36 AM
CLUCH
Has any one used or found an up grade for the LMH GAS clutch?
I want something that has bearings.
Joe
lyk2fly 05-21-2004 06:19 AM
RE: CLUCH
Hi Joe, there are several r.c. car clutches that are 32 pitch.....so the gear mesh will work. But you would have to machine some type shaft adaptor. You can look up some older O.S. CV12 conversion threads in this forum. Notasme has made the adaptors for the O.S. engines. The "car" clutches are usually supported by 2 ball bearings. Also I'm not sure about the size as far as alignment goes.
Mark
