120 won't initialize
I just got a new Hitec Eclpise 7 w/ Spectra Module. When I use it for my corona, the throttle does not work. I connected channel 3 to a servo and it works fine. I then started my Futaba 6XTA transmitter, which I had been using and the throttle initialized perfectly. I hope its only a setting I'm overlooking on the new transmitter. Any help is much appreciated.
Thanks, Howie |
RE: 120 won't initialize
You might want to try to increase to EPA to 120% or max whatever the Hitec can do. Good luck.
also, you need to set the trim on the throttle to absolute minimum.(I had to do this on fusion 35 with same radio to arm) This is a common problem with most ESC and computer radio. This is recommended in the manual I believe..
That did the trick!!! Turned the EPA to 125 and set the trim all the way down. It initialized!!!! Thanks guys :)
Howie |
Glad to see you got it working~!! Good luck.
| All times are GMT -8. The time now is 07:35 AM. |
